TermiPeteNZ 1330 Report post Posted November 23, 2016 Just wondering if anybody has hit this before. Noticed after stormy crap weather that the left rear seatbelt was damp - tilted rear seat, popped bolster off and found dampness on the wheel arch (near the wiring). Left it to dry out - inside the garage! Looking at my rear windscreen/window, looks like the rubber seal is pretty poked - perished, splitting and it looks like some little chunks have come out so guessing the window needs to come out and a fresh seal installed. Yet another plastic/rubber failure!!!! Oh well .... appreciate any advice/experience with this. Quote Share this post Link to post Share on other sites
RustyItalian 11 Report post Posted November 24, 2016 The joys of E60 ownership. Probably not related, but my E61 tail-light seal (between the coloured lense and black plastic) perished and let water into the boot area under the battery. Also got into the electrics causing a dead ship, couldn't even unlock the steering to straighten the wheels. $400 later... To be fair the car was a massive 8 years old. All I can advise is check the cavities either side of the boot also. Quote Share this post Link to post Share on other sites
treone 680 Report post Posted November 24, 2016 Any water in the rear passenger rear wells? Do you have a sunroof? if so blocked drain hoses could be a culprit. They run inside the roof cavity down the c-pillar to an outlet into the rear wheel arch/bumper (which is plastic). A common and notorious problem and a very bad design IMO :-( Quote Share this post Link to post Share on other sites
TermiPeteNZ 1330 Report post Posted November 24, 2016 Thanks guys. I'm not sure whether to be annoyed or relieved that all my BMW problems (other than 1 ignition coil) have been plastic and rubber related and not mechanical. Treone - no water in the footwells - I only picked this up from sorting the seatbelt for my youngest and feeling it was damp. Have asked Driscolls to check the sunroof drains. Quote Share this post Link to post Share on other sites
TermiPeteNZ 1330 Report post Posted November 25, 2016 22 hours ago, treone said: Do you have a sunroof? if so blocked drain hoses could be a culprit. They run inside the roof cavity down the c-pillar to an outlet into the rear wheel arch/bumper (which is plastic). A common and notorious problem and a very bad design IMO :-( Hey @treone - you were bang on the money - Driscoll checked the drains and yes they were clogged. Sorted! They also found the (probable) cause of the coolant loss - cracked expansion tank. Being replaced Monday. More (freakin) plastic failure!!!! I've had so much stuff sorted on this I need to keep it ... here's the previous stuff sorted during 1yr ownership and with 4 Autosure claims: engine oil seal radio recoded for NZ repl water pump, pulley, drivebelt repl thermostat repl 2 broken cupholders, worn trim fix driver seat back trim idrive replacement repl washer motor sort gearbox oil leak and rear coolant plate repl 1 ignition coil and 8 plugs repl swaybar links Quote Share this post Link to post Share on other sites
treone 680 Report post Posted November 25, 2016 Great to hear the water ingress was identified and sorted quickly. Believe me you dodged a bullet on that one! Hopefully you can now just drive and enjoy (for a few months at least ) 1 Quote Share this post Link to post Share on other sites
