Bryce 0 Report post Posted November 28, 2016 This may have been covered somewhere already, if so please direct me... I have an E46 wagon. It has constant warm air flowing in the windscreen and footwell vents, and also the center vents if rolled over to the red dots. The temp is set at it's lowest and the only way to stop the warm air is to switch the fan off. The aircon works fine for the central vents, but still hot windscreen and feet. There is power to the hot water valve, and a mechanic who replaced the radiator checked the valve and said it seemed to be opening and closing okay. He isn't a BMW specialist and couldn't figure out what was causing the problem. The number 62 fuse is fine. Coming into summer now it would be good to get this sorted. Any advise or experiences would be very appreciated! Cheers, Bryce. Quote Share this post Link to post Share on other sites
allan 295 Report post Posted November 28, 2016 From the info you have provided either the water valve or the final stage unit could be on the way out. Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted November 28, 2016 will be water valve , jammed up , rusty coolant etc 1 Quote Share this post Link to post Share on other sites
Bryce 0 Report post Posted November 28, 2016 15 hours ago, allan said: From the info you have provided either the water valve or the final stage unit could be on the way out. Thanks Allan Quote Share this post Link to post Share on other sites
Bryce 0 Report post Posted December 4, 2016 On 11/28/2016 at 3:51 PM, allan said: Used heater valve installed, bled, 20 minutes, fixed Thanks Allan Quote Share this post Link to post Share on other sites
