Eddie
E46 318i wagon v8 swap
Great work.
Did you use the e46 fuel pump and fuel filter, or was it not strong enough?
  On 2/6/2017 at 7:34 AM, zero said:
Great work.
I put the e38 fuel pump in the e46 holder
I've just been sorting out the little things like the air filter and washer bottle
The car has done just  over 1000km now and it's had a small oil leak on the left side since I first got it running, so I thought it's best I fix it
I have been tidying up the last of the wiring. Got the reversing lights and camera going again
  On 2/14/2017 at 10:02 PM, Michael. said:
Btw, what's that large tank on the driver side? Oil reservoir?
Yes it's the oil tank for the engine. The tank can hold 8l but only holds around 4-4.5 l  while running as the extra oil is circulating around the engine, filter,pump and oil lines.
The only pic I took while I was making the tank
  • Like 3
