Mr Hyde
E9x control arms
I bought these thinking they would adjust camber, they don't. They are lower control arms for adjusting toe in/out. Brand new they were never fitted. $80 and I'll deliver them anywhere in the country for free!
  • Made By OEM Approved and ISO Certified Manufacturers With Materials That Meets Or Exceeds Strict OEM Requirements
  • Machined Made From High Grade Alloy Steel and CNC Machined Aluminum
  • Direct Replacement Of Current Arms To Adjust To Custom Or Factory Specs After Being Lowered
  • Allows Approximately ~ +/- 3 Degrees Of Adjustment
  • Polyurethane Bushings With Aluminum Rod Inserts
Will they fit e46?
  On 7/15/2017 at 11:13 AM, zero said:
Will they fit e46?
Sorry I don't believe they do
SOLD - Congratulations John! PM and we can arrange how to get them to you
