smithy
e30 cheap upgrade
if your modafiying your 325i and u dont have alot of $$$$ to play with all u need to do is change the diff ratios standard 325i run a 3.70 if u change them to 4.10 this makes a huge differinc this will only work on manual one coz the autos allready have a 4.10 but any way if u change the ratios to a 4.10 u will have the same ratios as the USA spec M3 coz thay have the same gearbox as a normal 325i.
it will improve your acceleration, sure, but it reduces your top end and increases your fuel consumption.
If you want more power turbo it :D
A few things
First, learn to spell
Secondly, this is common knowledge and is already posted in the performance/maintenance threads.
Thirdly, changing the ratios doesn't increase performace
Lastly, running a 4.11 diff instead of a 3.73 will chew through your petrol like no tomorrow. Ask me how I know, oh you can't, I locked the thread.
This topic is now closed to further replies.
