actletpone
E36 318 icv
I'd just about bet my left testicle I have one spare sitting on my bench at home (just about bet because I don't trust my memory these days).
Will be home by tomorrow lunchtime at latest so will have a look for you, make sure it's the right one.
thanks for the responses, I had a cold start issue (had to hold foot on throttle for first 30 seconds or it engine would cut out. temp sensor is fine), icv was not buzzing then started buzzing when I tapped it with a hammer. The following couple of days ICV buzzed but still had cold start issue but now the cold start issue has completely disappeared? Will be in touch in needed, cheers
