Joshe30 9 Report post Posted October 1, 2017 (edited) thought it was about time to join this page and share some photos and yarns of my turbo e30 build that has been on going for nearly 3 years... not to sure what else i'm meant to say Edited October 1, 2017 by Joshe30 6 Quote Share this post Link to post Share on other sites
gjm 3299 Report post Posted October 1, 2017 Hi Josh! Car looks nice. Any details on the build? Quote Share this post Link to post Share on other sites
Joshe30 9 Report post Posted October 1, 2017 (edited) 1 hour ago, gjm said: Hi Josh! Car looks nice. Any details on the build? bought the car with the tech two kit already fitted and a m20b20 after owning it for around a year i wanted to make it more mine so i found a m20b25 for sale out of an old wreck, stripped it to the block and started again, standard rebuild bottom end with crank scrapers and sump baffle, the head got a lot of work done, port and polished intake and exhaust ports, re ground cam and rockers, bigger valve springs new valve stem steals and seats, 2mm cometic head gasket and apr head studs, custom intake manifold made as well as a custom fuel rail to hold the 660cc injectors. and to top it off a sinco turbo manifold with a garrett ta3410 and a 45mm hyper gate its had its first tune tune running 6-7 psi (waste gate pressure) and made 290rwhp so once it has a cert i will re tune on more boost around the 12-14psi mark ecu is a link g4 storm witch was installed and tuned by speed factor Edited October 1, 2017 by Joshe30 3 Quote Share this post Link to post Share on other sites
Mr Hyde 44 Report post Posted October 1, 2017 Welcome Josh, I am in awe of this car. I want a turbo e30 so badly. Sounds and looks like you've done an amazing job on it! Quote Share this post Link to post Share on other sites
Joshe30 9 Report post Posted October 1, 2017 thanks heaps faizal Quote Share this post Link to post Share on other sites
Funkyflynz 151 Report post Posted October 1, 2017 Super cool man! be keen to hear more details on the turbo setup, any issues you have had, good people to know when it comes to a project like this etc.. Quote Share this post Link to post Share on other sites
Joshe30 9 Report post Posted October 1, 2017 8 minutes ago, Funkyflynz said: Super cool man! be keen to hear more details on the turbo setup, any issues you have had, good people to know when it comes to a project like this etc.. the only problems I've had was my fuel reg fell to bits and sent fuel up the vacuum line and filed engine intake and inter cooler with fuel, haha so fitted a turbo smart pressure reg and now thats all sorted, and then about two weeks ago i went to take it out after sitting for about a month and it kept fuel cutting at 4000rpm on boost, replaced a lot of parts but turns out it was a rusty fuel tank haha, so fitted a new one last weekend and now its all going mint the biggest issue with the build was trying to keep the ac and fit an inter cooler oil cooler and line around it haha but really its been a good project and its nice to see it coming to the end, feel free to ask any questions on it cheers noah Quote Share this post Link to post Share on other sites
gjm 3299 Report post Posted October 1, 2017 1 hour ago, Joshe30 said: bought the car with the tech two kit already fitted and a m20b20 after owning it for around a year i wanted to make it more mine so i found a m20b25 for sale out of an old wreck, stripped it to the block and started again, standard rebuild bottom end with crank scrapers and sump baffle, the head got a lot of work done, port and polished intake and exhaust ports, re ground cam and rockers, bigger valve springs new valve stem steals and seats, 2mm cometic head gasket and apr head studs, custom intake manifold made as well as a custom fuel rail to hold the 660cc injectors. and to top it off a sinco turbo manifold with a garrett ta3410 and a 45mm hyper gate its had its first tune tune running 6-7 psi (waste gate pressure) and made 290rwhp so once it has a cert i will re tune on more boost around the 12-14psi mark ecu is a link g4 storm witch was installed and tuned by speed factor 14psi could be good for up to 450hp, depending on other factors (such as cams). I'm sure it's a lot of fun now, but more fun isn't a bad thing. Quote Share this post Link to post Share on other sites
_BRS_ 209 Report post Posted October 4, 2017 Hey Josh good to see it still going well for you. Quote Share this post Link to post Share on other sites
Joshe30 9 Report post Posted October 10, 2017 cheers blair, its starting to take shape, i really want to paint it again tho as its lost the clear coat on the right hand rear quarter, and it buggers me haha, one day it will be fully finished haha Quote Share this post Link to post Share on other sites
