eliongater
Sealant/Seam Sealer and rocker coatings
Currently undertaking some remedial work on my E28. Which has involved taking the guards off. What is the best way to remove the goopy sealant stuff and then what do I replace it with when I reattach the guard?
Also, I need to touch up the rocker panel protective coating and the rubberised underbody sealant. What should I use here (For each since I'm assuming they require different, but similar products)
Thanks Allan, however I'm not sure which of the many sealants to pick.
Do you know any panel beaters etc have a chat to them surely they would be able to steer you in the right direction. Or could it be as simple as reading the direction on the cartridge.
