BradMosen 16 Report post Posted November 22, 2017 How do you move up gears on your profile? Quote Share this post Link to post Share on other sites
Kepes 231 Report post Posted November 22, 2017 As far as I'm aware it's to do with how many posts you have. Not sure how many posts you need to shift up a gear! 1 Quote Share this post Link to post Share on other sites
BradMosen 16 Report post Posted November 22, 2017 14 hours ago, Kepes said: As far as I'm aware it's to do with how many posts you have. Not sure how many posts you need to shift up a gear! Ah okay, thank you Quote Share this post Link to post Share on other sites
HardBall66 135 Report post Posted November 22, 2017 I changed to second gear at 100. I didn't even have to push the clutch in. 2 Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3040 Report post Posted November 23, 2017 Yes, it is all related to your post count. When you hit certain numbers you will go up a gear "automatically" - does that make it an auto gearbox..?? 2 Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted November 23, 2017 28 minutes ago, E30 325i Rag-Top said: Yes, it is all related to your post count. When you hit certain numbers you will go up a gear "automatically" - does that make it an auto gearbox..?? Does the post count have a 3rd pedal? Cause if it doesn't then it must be auto Quote Share this post Link to post Share on other sites
