Lucan 196 Report post Posted November 22, 2017 Hey all, Google fails me, looking for E39 ignition, EWS and starter diagrams? Hardly anything decent found, compared to older model info out there anyway. Cheers, L Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted November 22, 2017 FYI Purchased an EWS bypassed (IMMO off) DME and the EWS module that came with it was faulty, shorted once I connected the battery and proceeded to melt an EWS module ground (pin 9) wire. So now I have to trace the dead/burnt wire up under the dash across to the passenger side choc block and find out why random accessory’s stay powered when the ignitions off. FML Quote Share this post Link to post Share on other sites
exextatic 160 Report post Posted November 22, 2017 If the DME has a true EWS delete, you can do without the EWS module. Just join the two higher-gauge wires together at the EWS module (pins 2 and 3, I believe), which will let the starter activate. Quote Share this post Link to post Share on other sites
