Carl 3 Report post Posted March 2, 2006 I need a motronic 1.3 chip for the ECU preferably from a 320i Doesn't have to be a stock chip but it does need to work BTW, don't bother with the E30zone chips, they don't work (tested) and Ant is a complete wanker Quote Share this post Link to post Share on other sites
m325i 732 Report post Posted March 2, 2006 I need a motronic 1.3 chip for the ECU preferably from a 320i Doesn't have to be a stock chip but it does need to work BTW, don't bother with the E30zone chips, they don't work (tested) and Ant is a complete wanker why do so many ppl on the forum rate them highly then? Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted March 3, 2006 I need a motronic 1.3 chip for the ECU preferably from a 320i Doesn't have to be a stock chip but it does need to work BTW, don't bother with the E30zone chips, they don't work (tested) and Ant is a complete wanker why do so many ppl on the forum rate them highly then? They're designed for the english fuel so do not work with the NZ stuff which is true of most chips. We may have the save RON and MON as other places but massively different additives that change the fuel characteristics.I lost 10kW peak power and 20 newtons on the dyno using the wild chip which was noticeable just driving around. The mild chip was even worse. Was cool having a 7200 redline though Quote Share this post Link to post Share on other sites
