User Name 19 Report post Posted July 17, 2018 (edited) Hi All, Should be a simple one, the internal dizzy cap cover broke (probably why misfired) Ideas on how to get the rotor holder out, Eg off end of cam so I can put replacement cover on. Centre bolt removed and wd40 + Some penetration oil seems to have pushed alot of crap out but still won't budge and can't afford to break it. Have considered standard size gear puller but means I need to take radiator out for enough room safely. Thoughts??? Will post picture when I get to a pc later. Thanks Edited July 17, 2018 by User Name Photo update Quote Share this post Link to post Share on other sites
Eagle 1787 Report post Posted July 18, 2018 Id probably thread longer bolts into the adapter holes with a flat plate etc or something for leverage and then some heat from gas torch Otherwise puller as you said or run a tap into the inside it if possible Quote Share this post Link to post Share on other sites
