modz 156 Report post Posted August 27, 2018 I've trawled the internet without much luck - can anyone clearly explain how to wire in the e46 reverse lights after a manual swap? I've sourced a Bosch connector, soldered on 1m of wire on both tails, attached to the reverse switch on the gearbox, threaded up into the cabin. Then following some guidance online from an E36 (I have E46) I believe my next steps are to located the plug that used to be in the shifter, find the Blue/Yellow and White/Green wires and attach them to the new tails leading back to the reverse switch on the gearbox. I realise silly to assume E36 and E46 are the same, so thought I'd check here first. Thanks Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted August 27, 2018 switch wires goes up into the ecu box area , i think taps into one of the relays there Quote Share this post Link to post Share on other sites
modz 156 Report post Posted August 27, 2018 1 minute ago, BM WORLD said: switch wires goes up into the ecu box area , i think taps into one of the relays there Awesome thanks Brent, I wondered if that would be easier. I'll wire that up today Quote Share this post Link to post Share on other sites
