Omni Carlo 3 Report post Posted September 8, 2018 Hello friends, i just want to check if someone can help..... i m looking to buy a F30 but i just want to confirm that there is a red line in the cluster it is inside the speedometer and RPM meter, but i just want to check if its in all the F30 or it depends ? thanks Quote Share this post Link to post Share on other sites
balancerider 830 Report post Posted September 9, 2018 The sport line and m-sport have the red line on the tacho / speedo. Luxury / Modern / SE don't. Quote Share this post Link to post Share on other sites
Omni Carlo 3 Report post Posted September 9, 2018 Thanks for that balancerider.... but how can i check if the car is msport.... the car i m looking to buy has paddle shift and the gear shift which comes with m sport..... but i m not sure..... Quote Share this post Link to post Share on other sites
balancerider 830 Report post Posted September 9, 2018 You can check the vin on a decoder eg bimmer.work, the seller should be able to give you the VIN Quote Share this post Link to post Share on other sites
qube 3571 Report post Posted September 9, 2018 to tell the difference between msport and non msport its pretty easy.. if you have looked at multiple examples of a particular model, your eye should start picking up the differences. If not google it or just tell us the link for the car you are looking at. I can tell you in 5 seconds if its a genuine msport or not Quote Share this post Link to post Share on other sites
