hugo_nz 166 Report post Posted September 8, 2018 I've ordered one and will report back once I receive the key. Pretty awesome. I've been following a thread on another forum about this swap but it involves desoldering chips etc which I know nothing about. Clearly this guy saw a gap and took it and if it works its a pretty cheap way to get a spare key too! https://rover.ebay.com/rover/0/0/0?mpre=...2508091127 Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3041 Report post Posted September 10, 2018 Not so sure what the point of that would be, as you don't actually end up with a spare key if you have to cannibalise your existing key to make the new one? So all you are doing is changing the case from the "old" style to the "new" style. You would really need to know what you are doing with a soldering iron in there as well, having smashed up some of these keys it's a pretty small and intricate pcb to start soldering things onto and off of. Good luck if you give it a go, let us know how you get on... 2 Quote Share this post Link to post Share on other sites
hugo_nz 166 Report post Posted September 10, 2018 Yep, if you were doing this yourself then it would be the case however this one is sold as already modified so you just program it to your car and you're done... Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3041 Report post Posted September 10, 2018 Ah, right. Didn't click on the link, just read your post. Yup, that is cheap for a spare key. Not sure that frequency is the right one for NZ New remotes though, is that the exact one you have ordered? Quote Share this post Link to post Share on other sites
hugo_nz 166 Report post Posted September 10, 2018 1 hour ago, E30 325i Rag-Top said: Ah, right. Didn't click on the link, just read your post. Yup, that is cheap for a spare key. Not sure that frequency is the right one for NZ New remotes though, is that the exact one you have ordered? Yup, that same one. 868mhz is the correct frequency. On f-series remotes the frequency is printed under the blade key. Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3041 Report post Posted September 10, 2018 Cool, you got the right one. I should have known that frequency, lol. Quote Share this post Link to post Share on other sites
