MD335 12 Report post Posted October 22, 2018 Hi folks, I am locked out of my E91 2008 335i completely. Even the emergency does nothing. I'm wondering if it is a dead battery? Please can anyone advise how to open the bonnet in this case so I can get a charger hooked up? Thanks in anticipation Martin Quote Share this post Link to post Share on other sites
Gaz 1076 Report post Posted October 22, 2018 Will the key blade not work in the driver's door? Quote Share this post Link to post Share on other sites
MD335 12 Report post Posted October 22, 2018 Hi Gareth, Nope - absolutely nothing which is what leads me to think the battery is dead Quote Share this post Link to post Share on other sites
Jacko 2272 Report post Posted October 22, 2018 (edited) The blade key is mechanical is it not? It should open the drivers door at least. Edited October 22, 2018 by Jacko 2 Quote Share this post Link to post Share on other sites
Gaz 1076 Report post Posted October 22, 2018 Just now, Jacko said: The blade key is mechanical is it not? It should open the drivers door at least. Unless the lock is faulty also but flat should not affect the door. You do have to turn it quite hard Quote Share this post Link to post Share on other sites
MD335 12 Report post Posted October 22, 2018 Thanks guys - I'm in! I did all the same things i did earlier. It just started working, and whilst I'm pleased I'm confused. The earth terminal on the battery was loose so I tightened that (obviously I had to reset date and time so that tells me battery was disconnected) Now seems to work consistently using both remotes, comfort access and the emergency key. Adaptive steering took 2 or three restarts of the engine but now initializes fine. Battery is fully charged so it must have been the earth connection. I appreciate all your suggestions folks. Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted October 22, 2018 1 hour ago, Gaz said: Unless the lock is faulty also but flat should not affect the door. You do have to turn it quite hard Yep, the lock should still turn regardless of battery voltage. I have picked the locks on several E9... series cars Quote Share this post Link to post Share on other sites
