drtimwright 104 Report post Posted November 6, 2018 So, a bit of squeaking suspension alerted me to a worn bump-stop. Just wondering what the process is to replace these is? Currently I'm assuming it's: Jack up the car Find the top of the strut mount (cabby so not much room in the boot) Unbolt it Replace the bump stop Bolt it back in Fix the interior of the boot Put the car down Or, should I unbolt it first then jack up the car? Hmm. SO MANY OPTIONS. Quote Share this post Link to post Share on other sites
dirtydoogle 383 Report post Posted November 6, 2018 Exactly as you have outlined. Easy peasy Quote Share this post Link to post Share on other sites
M3AN 4195 Report post Posted November 6, 2018 Do both sides at the same time and if you don't have the Z3 reinforcements then add those too (can be done later with the car on the ground). https://www.ecstuning.com/News/BMW_Z3_ECS_Assembled_Shock_Reinforcement_Kits_1996_1997_1998_1999_2000_2001_2002/ https://www.akgmotorsport.com/product/rear-shock-mount-reinforcement-set-e30-e36-e46-z3/ Cab may already have them? Check first. Quote Share this post Link to post Share on other sites
