OP6 27 Report post Posted November 15, 2018 I need 3, 4.05mm E30 M3 valve shims to complete the valve adjustment after getting the cams reground by Kelford Kams. I would also be interested in certain other sizes too, to replace what I have used. Quote Share this post Link to post Share on other sites
C-130 Hercules 572 Report post Posted November 15, 2018 Suggest get them direct from BMW. Not crazy expensive if you only need 3. Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3043 Report post Posted November 15, 2018 Not sure if I've got any that thick, I will have a look through what I have got spare and let you know. IIRC you had to order a whole "kit" the last time I looked at buying some specific sizes, so I ended up swapping some with a dealership. Quote Share this post Link to post Share on other sites
OP6 27 Report post Posted November 16, 2018 The dealership wanted me to buy the whole kit at a price that was eye watering! and on back order. I have found a mob in the USA that may have what I am after,( www.ipdusa.com/products/11641/100161-valve-shim-4-05mm), but their communication is woeful. I could try swapping some with the dealership, I had not thought of that. Happy to pay for immediate availability though. Cheers Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3043 Report post Posted November 18, 2018 As I thought, I haven't got any that thick. 3.90 is the fattest I've got sorry. Quote Share this post Link to post Share on other sites
OP6 27 Report post Posted November 19, 2018 Hey Jon, many thanks for having a look, greatly appreciated. Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3043 Report post Posted November 19, 2018 The service guys at CHCH BMW might have a set, try and speak to them see if you can swap a few over? I have seen them on USA eBay, as singles, quite small so Air Freight could still be reasonable? Quote Share this post Link to post Share on other sites
glen.riley.1990 27 Report post Posted November 19, 2018 I have just done the clearances on my E36, which i believe uses the same part numbers as an E30. Coombes Johnson in Hamilton was happy to supply singles, the sizes i needed were all EX Germany (3 weeks) @ $40 a piece. I ended up sourcing them online at $13US a piece + shipping. if you have the part numbers they are easy enough to find through any of the usual places. if you want any pointers send me a message. unfortunately none of the shims swapped out were that thick either. 1 Quote Share this post Link to post Share on other sites
OP6 27 Report post Posted November 20, 2018 Tried CHC BMW, they can order them in but not avail ex Germany till the New Year. Have some ordered with Pelican Parts at USD13+ each and they suggest they will be shipping at the end of the month, once the stock has arrived into their store, however I suspect (and hopefully I am wrong) they are expecting to be able to source from BMW Germany. Pelican Parts also have 4.05mm shims in stock from Volvo which I suspect are the same as the BMW ones, so have ordered some of those too. One way or another I will find some. 1 Quote Share this post Link to post Share on other sites
