Hewitt 1 Report post Posted December 27, 2018 Hi guys... Just wanted to find out if anyone has done or know someone who did a m10b18 to m20b20 conversion? Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted December 27, 2018 (edited) Don't. The M10 is not, in standard form, a performance engine. Solid, reliable, and responds very, very well to forced induction, but it is an old engine and compared to most modern engines, heavy, uneconomical and slow. (In stock form.) So is the M20B20. It combines the bad bits from the M10B18 and the M20B25 - it's bigger, a tighter fit in the engine bay, heavier, still not a performance engine by any means, and uses a lot of fuel. The M20B25 is a better engine in that it provides more performance, but other comments still apply. The M20 also responds well to forced induction (in particular). If you feel you must change the engine, look for a simple swap like a M4x. 16 valves, perkier performance, better economy, and still provides a tuning route should you wish to go that way. I'm still keen on the idea of a M43 in an E30 (fantastic economy, good performance in a lightweight car like an E30, simple) but I'm just a bit odd like that. ? If not a 4-pot swap, there are much better (and very well-documented) 6-cylinder transplants. M54s are popular for good reason. However, any 6-cylinder engine (imho) spoils the natural balance of the 4-cylinder cars. There's a good reason why BMW stuck with a 4-cylinder engine for the E30 M3 rather than develop the M20 engine for racing. Edited December 28, 2018 by gjm 1 Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3043 Report post Posted December 28, 2018 ^^yup, what he said. if you want to do an engine swap pick anything other than the M20B20, just not worth the effort. Quote Share this post Link to post Share on other sites
Hewitt 1 Report post Posted December 28, 2018 Thanx for the advice guys but the problem is that i already bought the M20B20,already in the car. This conversion is basically a starter pack for me as its the first BMW for me.I used the M10b18's flywheel and starter but having issues with the starter. Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3043 Report post Posted December 28, 2018 Ahh ok, previous stuff not too relevant then, sorry. What is the starter problem, is it spinning but not engaging on the flywheel? Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted December 28, 2018 1 hour ago, Hewitt said: This conversion is basically a starter pack for me as its the first BMW for me.I used the M10b18's flywheel and starter but having issues with the starter. The M10 starter is unique to the M10 engine, but whether that is because of the flywheel (which you've used) or for another reason I couldn't say without a lot more investigating. Quote Share this post Link to post Share on other sites
turbolizard 38 Report post Posted December 28, 2018 Is the M10 ring gear the same diameter as the M20? I don't know if they are the same or not, but something to check. If the diameter is close but different then the starter may be in slightly the wrong position with respect to the ring gear when installed into an M20. Quote Share this post Link to post Share on other sites
Hewitt 1 Report post Posted December 28, 2018 Yip,i think ill start with the starter before removing the gearbox again,coz when the starter is tightened the engine does not turn but when the starter is a bit loose,not fully tightened,it makes a grinding noise....thanx for the advice guys . 1 Quote Share this post Link to post Share on other sites
