kiwi6539 3 Report post Posted February 12, 2019 Hello My plastic white/clear switch has broken the tip off. So indicators stay on unless I turn off manually I've got a spare switch while unit stalk etc. But can't get it apart to get to plastic part I need does it come apart?. I can't find how to do or picture guide anywhere. This is spare part I have it cut from main wiring harness. Or can you separate stalk assembly to get spare part. I've attached picture. I need that white part and have no idea how to fix. Any advice would be great Cheers Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted February 12, 2019 A new / second hand switch unit is required Quote Share this post Link to post Share on other sites
kiwi6539 3 Report post Posted February 12, 2019 Hi. Ok thank you. Do you have any idea of cost of new?. I just fixed it but for how long I don't know. Drilled a tiny hole into it where snapped and stuck drill bit in with some glue cut to length its working but have driven yet. Will see Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted February 12, 2019 I bet Brent has a used one.Prolly same unit used in e32 too maybe e 36 as well 1 Quote Share this post Link to post Share on other sites
allan 295 Report post Posted February 12, 2019 e34 89 530i bmw fans shows two indicator switchs listed part No 61311382866 shows it was used on the e34 525, 530. E32 730, 735. The second one used with on board computer part No 61311382868 used in the e34 525, 530, 535. E32 730 735, 750 Pelican has 61311382868 showing at $120.25 us then the freight as well. any help Quote Share this post Link to post Share on other sites
kiwi6539 3 Report post Posted February 12, 2019 Hi. Yes thanks for the help. I've done a temporary fix on it and will see how long it lasts. Quote Share this post Link to post Share on other sites
