Mark312
N52b25 to N52b30 engine swap questions
Hi guys,
I am looking at replacing my 525i high mileage N52b25 engine which suffers from the dredded lifter clatter and excessive oil consumption to a N52b30. From what I can see both the 525 and 530 share the same ZF6HP transmission, radiator + other ancillarys and are practically 1/1 identical apart from displacement.
My question is apart from swapping over and possibly coding the b30 DME and CAS module - is there anything else members would think is a stumbling block?
Thanks in advance
Cheers!
Edited by Mark312
