gjm 3299 Report post Posted March 9, 2019 I was talking with someone about this yesterday. He has a vehicle which has passed several WoFs without issue, yet on inspection probably shouldn't (from a documentation) perspective be on the road. Esentaily - the chassis number is fundamentally wrong. Everything else is correct and there's nothing that seems amiss, but the VIN suggests it's a different vehicle to the one it is described as. I've seen similar in other circumstances, including a vehicle accurately described and with rego number matching that on rego plate and database, but with a VIN for a different vehicle. The VIN plate on the vehicle displayed a different rego number (stored in the NZTA database for a vehicle matching the description) and a chassis number which was correct for the vehicle. Is it possible to rectify this situation? Theoretically a WoF inspector will pick this sort of thing up, but how do you then go about reconciling the physical and documented records? Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3027 Report post Posted March 10, 2019 Yes, have done similar a number of times. MR16 form and lots of supporting documentation. It helps if you can point out (without blame) how and where the error occurred. if successful a note is entered on the MVR linking the new VIN to the previous one I believe. 1 Quote Share this post Link to post Share on other sites
