BrokeMyWallet 10 Report post Posted March 27, 2019 Anyone here DIY this? Just wanting to get stuck into it. What kind of cable/software setup are you using? I want to do some simple stuff like code doors to auto-lock on drive off etc. Also want to have a go at applying a fix specific to my car that is causing it to think the doors are open even though they're not. TIA Quote Share this post Link to post Share on other sites
BreakMyWindow 1974 Report post Posted March 28, 2019 What car? Quote Share this post Link to post Share on other sites
BrokeMyWallet 10 Report post Posted March 28, 2019 E53 and E82 Quote Share this post Link to post Share on other sites
Gaz 1076 Report post Posted March 28, 2019 E82 autolock on driveaway can be done through the BC button and indicator stalk 1 Quote Share this post Link to post Share on other sites
BrokeMyWallet 10 Report post Posted March 28, 2019 Already done. What about the X5? Quote Share this post Link to post Share on other sites
BlackrazorNZ 83 Report post Posted March 28, 2019 BimmerCode and a Kiwi3 will get you 90% of what most people want to achieve safely and relatively simply. Quote Share this post Link to post Share on other sites
BreakMyWindow 1974 Report post Posted March 28, 2019 For the e53 nscexpert will be useful for what you’re wanting. There is a German to English translation cheet sheet floating about online. Any D-can cable should do. Quote Share this post Link to post Share on other sites
sobanoodle 46 Report post Posted March 28, 2019 3 hours ago, BlackrazorNZ said: BimmerCode F-series only. Carly is more like it. Quote Share this post Link to post Share on other sites
BrokeMyWallet 10 Report post Posted March 28, 2019 I also need to apply this fix. https://bmw-worldzz.blogspot.com/2016/05/instruments-door-open-messagechime.html?m=1 So those easier to use apps won’t do the job. Need ncs expert, winkfp, ISTA/P etc. I have ISTA/D working so far, was hoping someone could help with the setup of the apps. Quote Share this post Link to post Share on other sites
