lbo99
E46 M3 Engine and Transmission Mounts
Thinking of replacing the engine and transmission mounts of my car as they are all quite worn. Has anyone here happened to replace theirs before? I'm actually thinking to replace mine with the UUC ones instead of the OEM as they provide a lifetime warranty. Feel free to let me know your opinions, cheers :)
UUC Engine Mounts + Transmission mount - http://store.uucmotorwerks.com/engine-mounts--transmission-mounts-package---oe-replacement-rubber-for-e36-e46-z3-z4-p1895.aspx
Pretty easy job.
The m3 mounts are slightly firmer than the stock ones - about 15% I think.
Don't be surprised if your old mounts come out in pieces or look severely damaged as these often fail on our cars.
Make sure you torque the trans mounts to the correct torque  or if you overtighten you will get vibration.
  • Thanks 1
