325_driver 422 Report post Posted July 7, 2019 So after changing the wheels, the tyre pressure warning light came on and i'm assuming that the old wheels had TPS installed on the old stock standard wheels If i reset it, will it keep coming back? Do i have to do anything to disable it completely? Or do i have to get the TPS valves transfered over to the new wheels lol Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted July 7, 2019 These dont have TPS, instead use the wheel speed sensors to detect the rolling diameter. Set your tyre pressure, reset the system and you will be ok. It will only detect loss of pressure in relation to the other wheel and not once it drops below a certain pressure. If you ever top up the pressure or change it, you need to reset the system Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted July 7, 2019 1 minute ago, Gaz said: These dont have TPS, instead use the wheel speed sensors to detect the rolling diameter. Set your tyre pressure, reset the system and you will be ok. It will only detect loss of pressure in relation to the other wheel and not once it drops below a certain pressure. If you ever top up the pressure or change it, you need to reset the system Thank God lol, So just go to the warning, hold that side button for 5 seconds? Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted July 8, 2019 Idrive? If not, engine on, and use the flicker switch and BC button to go to the reset option, and press and hold. It will then re-calibrate as you drive off. Youtube is handy for this 1 Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted July 8, 2019 Yeah sorted, thanks for clarifying I didn't have tyre pressure sensors lol Quote Share this post Link to post Share on other sites
