duluth 41 Report post Posted August 1, 2019 Just got my car back from the mechanics today, Page European, and they said my transmission is cooked. Should I get the transmission repaired/rebuilt or opt to buy a used transmission with 24000kms for $500 and get someone to put it in. If i were to try the second option where could i get such a swap done? Wellington based. Thanks in advance. Quote Share this post Link to post Share on other sites
Eagle 1776 Report post Posted August 1, 2019 Rebuild could be expensive but depends on what has actually failed and how far you rebuild it. A good second hand unit with new fluid\filter and probably a rebuilt torque converter is what id do. Jon @ Auto38 is recommended by many Wellington members here. 1 Quote Share this post Link to post Share on other sites
duluth 41 Report post Posted August 1, 2019 53 minutes ago, Eagle said: Rebuild could be expensive but depends on what has actually failed and how far you rebuild it. A good second hand unit with new fluid\filter and probably a rebuilt torque converter is what id do. Jon @ Auto38 is recommended by many Wellington members here. Cheers, is swapping out the transmission, my most likely course of action, something Jon at Auto38 would be able to do ? Quote Share this post Link to post Share on other sites
Eagle 1776 Report post Posted August 1, 2019 Yes, straight forward and a fairly quick job on a hoist. While everything is off its usually a good idea to do rear engine seal, transmission seals and driveshaft parts if they need doing or are on their way out, saves money down the line if you are keeping the car for awhile. 1 Quote Share this post Link to post Share on other sites
duluth 41 Report post Posted August 13, 2019 On 8/1/2019 at 7:07 PM, Eagle said: Yes, straight forward and a fairly quick job on a hoist. While everything is off its usually a good idea to do rear engine seal, transmission seals and driveshaft parts if they need doing or are on their way out, saves money down the line if you are keeping the car for awhile. Was quoted 8-10 hours for the job, does this seem about right ? Quote Share this post Link to post Share on other sites
Eagle 1776 Report post Posted August 13, 2019 Depends on what they are doing exactly?. Purely transmission removal and replacement should be approx 4-5 hr job. Quote Share this post Link to post Share on other sites
