nzsapper 82 Report post Posted September 9, 2019 Looking for help re fault codes Chap at work has 2007 320i ran a scan and has the following codes, I know absolutely nothing about fault codes so please excuse my ignorance in this area. I have tried to find info and what I find doesn't look like below He is wondering what should he deal with first A0AA CAS:Control unit fault present A0AB CAS: Control unit fault not present A0B2 CAS: Supply terminal 30E/30L not present AOBO CAS: Input brake lights, implausible not present A0B5 CAS: Fault road speed signal present 2F9E DME: Thermal oil-level sensor not present 2A6F DME: Valvetronic minimum lift exceeded present What does all this mean?, thanks in advance Quote Share this post Link to post Share on other sites
kwhelan 242 Report post Posted September 9, 2019 first step is to clear any old ones out, run car and see what reappears. some of them are probably generic glitches from some time ago I take it you have something wrong or are you just curiously looking Quote Share this post Link to post Share on other sites
nzsapper 82 Report post Posted September 9, 2019 Cheers - not my car belongs to chap at work, assume he must have something wrong to run them first. Will pass on Quote Share this post Link to post Share on other sites
