pauly 16 Report post Posted September 30, 2019 (edited) As per subject, looking at some style 22 17" with 235/40 Semis. Offset is 41. Will they be OK on my 318ti E36? TIA Edited October 1, 2019 by pauly Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted September 30, 2019 Depends on the offset of the wheel. If the offset is correct they will fit - if not they will rub. Quote Share this post Link to post Share on other sites
pauly 16 Report post Posted October 1, 2019 (edited) 1 hour ago, zero said: Depends on the offset of the wheel. If the offset is correct they will fit - if not they will rub. They are style 22 offset is 41, where on an M3. Edited October 1, 2019 by pauly Quote Share this post Link to post Share on other sites
Statek 87 Report post Posted October 1, 2019 Is that a square set Paul? According to http://www.bmwstylewheels.com/bmw/22 the Style 22s only came in 17x7.5. That tyre width is pretty chunky - are the 235s only on the rear or on all 4? Quote Share this post Link to post Share on other sites
pauly 16 Report post Posted October 1, 2019 (edited) 4 minutes ago, Statek said: Is that a square set Paul? According to http://www.bmwstylewheels.com/bmw/22 the Style 22s only came in 17x7.5. That tyre width is pretty chunky - are the 235s only on the rear or on all 4? It's a square set Kris, all 235s. There're a few pics of compacts on that link with 22s. Edited October 1, 2019 by pauly Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted October 1, 2019 Yes they will fit fine with that offset. Quote Share this post Link to post Share on other sites
Statek 87 Report post Posted October 1, 2019 Yup, should fit fine. I wonder whether the tyres aren't too wide for it though still, any time on a track is always fun! Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted October 1, 2019 Yes tyres are a bit too wide for the rim, but not dangerously so. You definitely wouldn't go wider on a 7.5 rim. Also bear in mind that the speedo will be slightly off with that aspect ratio, but that wont matter on the track. Quote Share this post Link to post Share on other sites
pauly 16 Report post Posted October 1, 2019 4 minutes ago, zero said: Yes tyres are a bit too wide for the rim, but not dangerously so. You definitely wouldn't go wider on a 7.5 rim. Also bear in mind that the speedo will be slightly off with that aspect ratio, but that wont matter on the track. but you reckon I'd be OK for (no) rubbing with that offset and width? Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted October 1, 2019 Can you not try them ? I was running 235/35/17 on 8.5" ACS wheels on mine. Got occasional rub and I had pretty stiff suspension which was lowered as well Quote Share this post Link to post Share on other sites
pauly 16 Report post Posted October 1, 2019 23 minutes ago, B.M.W Ltd said: Can you not try them ? I was running 235/35/17 on 8.5" ACS wheels on mine. Got occasional rub and I had pretty stiff suspension which was lowered as well They are in Auckland and I'm in Masterton so no unfortunately! Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted October 1, 2019 Mines sold. I'm sure someone on here might be able to help. Has your got a standard suspension set Up ? Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted October 1, 2019 2 hours ago, pauly said: but you reckon I'd be OK for (no) rubbing with that offset and width? Yes you will be fine. Quote Share this post Link to post Share on other sites
