thorburn
Speeduino plug and play ecu
I've got a bunch of boards to suit m52 single vanos(green board) and m50nv, m50 vanos, m4x and m60(Black board).
Boards are $45 shipped
Can order in all parts if needed.
Basic component kit for m50 $300 and m52 $350.
Can add baro pressure sensor, Bluetooth, extra outputs.
These are pazzis designed boards and I will be donating $5 of every board sold, to him.
These are a DIY kit. I will explain more if people are interested
  • Like 3
I built one for an M52 a few months back. I fit it into an MS41 Housing. Surprisingly easy to put together.
I assume these are still batch fire (semi-sequential)?
Is the cam position sensor supported?
Do you have a source for the ECU connectors?
  • Like 1
Maybe is possible with the teensy board. I haven't kept up with it the teensy capabilities.
What benefits are you trying to get from full sequential?
I've been recycling second hand connectors. Haven't tried ordering the motronic ones off aliexpress.
Did you fit a v3 in there with jumpers?
Glad to hear there are a few people in nz going for the cheaper option
  • Like 1
