Subritzky
What on earth are these?
?and where is the top one supposed to be going I found the other end beginning to melt on the side of the block lol
E39 525i auto 2001
Thanks in advance.
Looks like a home made earthing kit, supposed to eliminate any poor earths in the factory wiring, pretty much pointless on an E39 assuming the original wiring is ok. I would be pulling it all out.
  • Thanks 1
Agreed on grounding kit. Causing no harm leaving it in there as long as you stop it melting. Also probably causing no benefit leaving it in there too though. Very common on jap import stuff.
  • Thanks 1
Cheers lads seeing as it isn't factory and causes no harm in or out I'll just remove the top earth that's free hanging and leave the rest in cheers. Thread closed.
