BMTHUG
E30 4hp22 switchable automatic transmission
As the title states, have an electronically switchable (economy, sports etc) 4hp22 e30 box for sale. Will come with the auto shifter, switch for shifting and EGS ecu as well as driveshaft if required. No trans cooler lines as they were used elsewhere. Surplus to requirements but shifted absolutely beautifuly when removed. 130k. After $300 ono for the lot. Pick up in Glenfield 02102916373
Bump will consider any offers thrown at me so try your luck
Not sure if anyone who's looked at this has seen my thread in the "off topic" section, I can probably bring this from Auckland anywhere to Invercargill (along the main route) in mid December for nothing if that helps.
you're a good dude man!
