Mad_Max 236 Report post Posted December 1, 2019 Ok so I'm playing with the idea of getting a tune for the E53 X5 with M57D30. Just wondering if anyone here has a way of reading and reflashing the DME? I have been told Kess V2 is probably the best way but would like to avoid shelling out more $$$ on something that will probably only get used once, so I'm looking for alternative software/methods. I have a K+DCAN cable, ISTA -D and -P, NCS etc. all set up and working but I don't think these have the ability to do this, is that correct? Quote Share this post Link to post Share on other sites
promo 93 Report post Posted December 1, 2019 Hi there, none of those cable will able to flash a custom rom. I have tools to flash your DME. Since you're not based in wellington you will need to send me your ecu and ill tune it/flash for you Pramod Quote Share this post Link to post Share on other sites
Mad_Max 236 Report post Posted December 1, 2019 (edited) 14 hours ago, promo said: Hi there, none of those cable will able to flash a custom rom. I have tools to flash your DME. Since you're not based in wellington you will need to send me your ecu and ill tune it/flash for you Pramod Hmmm is that something that can be done through the OBD port, or does the DME have to come out and be opened up? It's my daily driver and I can't really be without the car for a week, however I'm coming through Wellington on the 7th and back down on the 12th. Interesting that you say it can't be done with Kess V2, yet the person doing the tune has recommended using that over anything else, and has done many of these tunes for the X5's before. Edited December 1, 2019 by Mad_Max Quote Share this post Link to post Share on other sites
promo 93 Report post Posted December 1, 2019 (edited) Sorry i meant K+DCAN cable cant do it. Kess v2 and Ktag can. i have both, also bitbox, pcm flasher, mmc flasher etc. have done a lot of remaps different cars Edited December 1, 2019 by promo Quote Share this post Link to post Share on other sites
Mad_Max 236 Report post Posted December 2, 2019 48 minutes ago, promo said: Sorry i meant K+DCAN cable cant do it. Kess v2 and Ktag can. i have both, also bitbox, pcm flasher, mmc flasher etc. have done a lot of remaps different cars Ok cool, thanks for the clarification. Does the DME need to be removed or can you do it through the OBD port with Kess? Want to flick me a PM about how you'd do it, what sort of results you'd expect and how much you'd charge if I can arrange the timing to suit? Quote Share this post Link to post Share on other sites
