jon dee 500 Report post Posted September 21, 2020 I've been jumping around smiddy Currently I am on MHD 1+ ver 8 without linear throttle because I changed too many things in one hit which makes it hard to say what changes are due to each item changed. After I've run ver 8 for a bit longer I will swap back to ver 9 as Herb recommends. Then I can make a proper comparison without any possibility of linear throttle interfering. The reason I like feeling the torque roll in is that I spent too long driving 2 litre N.A. sales rep specials... either change down to overtake or get a decent run up At that time my toy was a little 1600 twincam Corolla and that had the same problem. Trying to overtake anything in 5th gear was a high risk operation as the car barely responded when the throttle was floored. After I bolted on a twinscrew supercharger I got the kind of response shown in the attached graph. The difference was night and day... with boost the Corolla was ALIVE !!!! I could overtake safely in 5th with just a gentle increase in pressure on the throttle. And now that I have shaken a few extra hp loose from the 335i I have that same kind of throttle response... torque on tap with just a gentle push on the throttle. There is no way that I can give feeling up now... I'm addicted I know that linear throttle works and the power is still there on tap, but it is soooooooo satisfying to be able to get that push in the back with just a nudge on the gas pedal and know that there is more on tap if needed. Cheers... Quote Share this post Link to post Share on other sites
jon dee 500 Report post Posted October 1, 2020 OK... so I flashed the Stage 1+ ver 9 beta tune this afternoon so I could make a back to back comparison with the ver 8 tune I have been driving on for the last week. Based on a short outing over part of my "test track" I have to say that the ver 9 feels more sophisticated than the ver 8. In Drive the trans is not so twitchy... not so keen to go down a gear when it is not needed and making better use of the low end torque by shifting up a little earlier and then holding gears down to a slightly lower rpm. Not a radical change from ver 8 but smoother and a little reminiscent of the factory stock tune with a lot less dawdling to get moving In Sports mode the same thoughts apply... ver 9 makes better use of the low end torque by not jumping between gears unnecessarily and revving out when taking a higher gear would be a better choice.. While not at race pace (narrow, twisty public road) I did give it a bit of a tickle up and I think gear management has improved and the power also seems to have been improved thru the mid range. All totally subjective of course, but I definitely think the ver 9 tune can deliver the improvements in 1/4 mile times that Herbmeister has measured. Stands to reason really... MHD is not going to release a new version of a tune unless it offers an improvement over the previous version. So no reason to upgrade to ver 8 now, just go straight to ver 9 and be happy Cheers... Quote Share this post Link to post Share on other sites
KwS 2451 Report post Posted October 1, 2020 I wish I had these options when I had my e91, it sounds like the mhd tune has become a lot more driveable since then. Quote Share this post Link to post Share on other sites
jon dee 500 Report post Posted October 3, 2020 As my dear old mother always said.... "The proof of the pudding is in the eating" So like all subjective opinions on new modifications, I will need to revisit this topic after a few months of driving with this version. The 335i has a great thirst for BP98 at $2.35 a litre when pedaled hard in Sports mode, so I spend most of my time in Drive and only drop into Sports when there is a chance to exploit the extra performance. Manual mode is there if required, but to be honest, the car does such a good job of changing gears and keeping the engine on the boil that the only reason I use manual is to be able to start in second gear. Cheers... PS: If anyone has a technique for getting the 335i N54 to start in second gear in Sports mode, I would love to hear about it. Quote Share this post Link to post Share on other sites
