*Glenn* 856 Report post Posted February 9, 2016 Any help on E90 '07 model with i-drive is much welcomed in regards to changing the radio area from japan to oce Regards, George Nairobi, Kenya. Do you have a local dealer close by ? Quote Share this post Link to post Share on other sites
waweru.george 0 Report post Posted February 9, 2016 Hi Glen.. yes there is.. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted February 9, 2016 Suggest you talk to them...needs coding Quote Share this post Link to post Share on other sites
digital_frankenstein 10 Report post Posted February 10, 2016 Hi Glen.. yes there is.. Suggest you talk to them...needs coding If you do talk to them, do you mind sharing what their estimate or eventual price for the work is/was? I'm stuck on Jap too. Although I don't listen to the radio, it would be good to have just in case. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted February 10, 2016 If you do talk to them, do you mind sharing what their estimate or eventual price for the work is/was? I'm stuck on Jap too. Although I don't listen to the radio, it would be good to have just in case. Talk to Joe @ Eurosurgeon in Penrose Quote Share this post Link to post Share on other sites
waweru.george 0 Report post Posted February 13, 2016 Spoke to them. Said they cant do a thing as it's a risk of tempering with the whole radio unit. Quote Share this post Link to post Share on other sites
Santoshdurai 5 Report post Posted April 27, 2016 (edited) Thanks to AK330i. I exactly coded as below and it worked like a charm. Mine was a 2007 e92 335i. Saved me a few hundreds The only thing to note is after coding shutoff the car and give it like 5 , 10 mins to start picking up NZ frequencies. When I checked immediately after coding, I saw FM and AM disabled. After a while they came up automatically. These are the settings that I changed in the CCC idrive: CHOST ------------------------------------------- LAENDERVARIANTE_GT ece CTUNE ------------------------------------------- RDS_AF_FUNKTION_CCC rds_ein_af_automatisch LAENDERVARIANTE_TUNER_ANT ece CAPPL ----------------------------------------- LAENDERVARIANTE_TUNER ece Edited April 27, 2016 by Santosh 1 Quote Share this post Link to post Share on other sites
waweru.george 0 Report post Posted May 4, 2016 Santos's.. Thanks for the feedback and guidance.. Is the a way to access the code through Idrive or one has to go through the odbc or cable connector.. Thanks Quote Share this post Link to post Share on other sites
JST 0 Report post Posted June 11, 2016 Hello all, Can anyone please offer some advice? I have an e46, 2004 330xi Japanese export. I have managed to change the head unit language into English and change the radio frequency to a scale that recieves local radio - thanks to those that posted the info on this site. I'm now trying to get the Nav to work. I just got a second hand MkIV Nav unit today and hoped that it would be a plug and play solution, however when I removed the existing Jap Nav Unit, I realised that the wires / plugs were different! Do any of you guys know how I can connect the new MkIV Nav unit? Is there somewhere where I can either order a bespoke convention loom or any other information / guides on the web? I have read through this forum in detail - but there is nothing (least not that I could find) that covers this. Any help / advice would be greatly appreciated. Many thanks, Jason Quote Share this post Link to post Share on other sites
Neal 576 Report post Posted June 11, 2016 Try http://www.info.org.nz/?download=e39_jap_2_euro_nav_conversion_mar09.pdf Quote Share this post Link to post Share on other sites
waweru.george 0 Report post Posted June 12, 2016 Thanks to AK330i. I exactly coded as below and it worked like a charm. Mine was a 2007 e92 335i. Saved me a few hundreds The only thing to note is after coding shutoff the car and give it like 5 , 10 mins to start picking up NZ frequencies. When I checked immediately after coding, I saw FM and AM disabled. After a while they came up automatically. These are the settings that I changed in the CCC idrive: CHOST ------------------------------------------- LAENDERVARIANTE_GT ece CTUNE ------------------------------------------- RDS_AF_FUNKTION_CCC rds_ein_af_automatisch LAENDERVARIANTE_TUNER_ANT ece CAPPL ----------------------------------------- LAENDERVARIANTE_TUNER ece Quote Share this post Link to post Share on other sites
waweru.george 0 Report post Posted June 12, 2016 Thanks to AK330i. I exactly coded as below and it worked like a charm. Mine was a 2007 e92 335i. Saved me a few hundreds The only thing to note is after coding shutoff the car and give it like 5 , 10 mins to start picking up NZ frequencies. When I checked immediately after coding, I saw FM and AM disabled. After a while they came up automatically. These are the settings that I changed in the CCC idrive: CHOST ------------------------------------------- LAENDERVARIANTE_GT ece CTUNE ------------------------------------------- RDS_AF_FUNKTION_CCC rds_ein_af_automatisch LAENDERVARIANTE_TUNER_ANT ece CAPPL ----------------------------------------- LAENDERVARIANTE_TUNER ece Please share and or explain the procedures used.. Quote Share this post Link to post Share on other sites
waweru.george 0 Report post Posted June 12, 2016 Please share and or explain the procedures used.. Quote Share this post Link to post Share on other sites
waweru.george 0 Report post Posted June 13, 2016 Please share and or explain the procedures used.. Quote Share this post Link to post Share on other sites
thexpat 0 Report post Posted June 20, 2016 Hi Jochen thanks for the informaton re stereos, the compatability of the newer stereos with older cars and multi info displays was exactly what i needed to know. cheers johnstations Hi jochen can advise how to reprogram my car idrive unit ccc to Newzealand stations my unit dosen't have any MODE button so not sure how to reprogram can you help Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted June 20, 2016 (edited) It's a shame... but Jochen hasn't been on this forum since the 8th of January 2015 and others that can help with these problems seem to have moved on as well Edited June 20, 2016 by *Glenn* Quote Share this post Link to post Share on other sites
bigballershotcaller 0 Report post Posted September 14, 2016 After a bit of fiddling getting all of the software installed and working, I successfully coded the changes referenced in Santosh's earlier post on my own 2008 E92. in the FM radio under "All Stations" I now have all of the regular stations appearing However, when I go into manual frequency selection, it's still got the old Japanese frequencies... Not sure why that is, but I'll check again tomorrow. Big thanks to Santosh for the tips on installing everything, it's a bit of a minefield, but good once you get it working. Quote Share this post Link to post Share on other sites
tonym 0 Report post Posted January 15, 2017 just wondering how to reporgrame my BMW 528i -2010 it is a Jap import and want to convert radio to NZ Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted January 19, 2017 On 1/15/2017 at 1:41 AM, tonym said: just wondering how to reporgrame my BMW 528i -2010 it is a Jap import and want to convert radio to NZ You have an E60 or an F10, you need to use BMW software to reprogram. Try Guido at the BMW workshop on 317 Great North Rd, Grey Lynn, Auckland 1245 1 Quote Share this post Link to post Share on other sites
vinaymorar 0 Report post Posted May 5, 2017 How can I do this for 2008 BMW 116i, it doesn't have "M" button at all ? Please help Quote Share this post Link to post Share on other sites
vinaymorar 0 Report post Posted May 5, 2017 On 08/04/2006 at 11:30 PM, jochen said: Here's a useful 'How to' for BMW fans: HOW TO CHANGE JAPAN RADIOS TO NZ FREQUENCIES - WITHOUT A BAND EXPANDER Factory fitted BMW radios from around 2000 onwards have a 'world tuner' inside them. The same radio can be used anywhere in the world. The radio can be programmed to operate in JAPAN mode (FM = 70-90), or in OCEANIA or EUROPE mode (FM=87.5-108). They also do a USA and CANADA mode but that's not useful here in NZ. BMWs imported from Japan have their radios set to JAPAN mode (wonder why?) These can be readily re-programmed to NZ frequencies as follows: 1. Switch on radio 2. Within 10 seconds, press and hold down the 'm' button until the serial number appears (takes around 10secs) to enter the radio's service menu. 3. Use the + or - buttons to cycle through the menu settings until you see AREA JAPAN or just JAPAN (varies a bit depending on radio) 4. Use the 1...6 buttons to select either OCEANIA (or OCE) or EUROPE - both are valid settings for New Zealand - see below for differences. 5. Switch radio off to store the change Voila! Your radio has now bee reprogrammed to receive NZ FM frequencies! Also, the cool RDS features will now be available. Differences between OCEANIA and EUROPE modes on an E46 Business RDS radio (other radios may vary slightly): a) EUROPE has LW, MW and FM. OCEANIA has AM and FM only. OCEANIA shows ST for a FM stereo station; EUROPE doesn't show anything for stereo or mono FM stations. c) EUROPE has the softkeys set to RDS and TP; OCEANIA has RDS and PTY Which ever one you choose - OCEANIA or EUROPE - is up to you, they both work. I hope you find this info useful, and that the forum moderator makes this a 'sticky' PS: If anyone wants any info or help with BMW radios - talk to me. I've helped around 80 BMW owners convert from Japan radios to proper NZ radios for their BMWs, thus keeping the vehicle in original condition, and obtaining proper radio reception. Send me an email for more info! Cheers, Jochen what is your email address ? How can I do this for 2008 BMW 116i E87, it doesn't have M button at all Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 5, 2017 Talk to Joe @ Eurosurgeon in Penrose Quote Share this post Link to post Share on other sites
Flyhalf360 0 Report post Posted June 3, 2017 On 2006-4-8 at 11:30 PM, jochen said: Here's a useful 'How to' for BMW fans: HOW TO CHANGE JAPAN RADIOS TO NZ FREQUENCIES - WITHOUT A BAND EXPANDER Factory fitted BMW radios from around 2000 onwards have a 'world tuner' inside them. The same radio can be used anywhere in the world. The radio can be programmed to operate in JAPAN mode (FM = 70-90), or in OCEANIA or EUROPE mode (FM=87.5-108). They also do a USA and CANADA mode but that's not useful here in NZ. BMWs imported from Japan have their radios set to JAPAN mode (wonder why?) These can be readily re-programmed to NZ frequencies as follows: 1. Switch on radio 2. Within 10 seconds, press and hold down the 'm' button until the serial number appears (takes around 10secs) to enter the radio's service menu. 3. Use the + or - buttons to cycle through the menu settings until you see AREA JAPAN or just JAPAN (varies a bit depending on radio) 4. Use the 1...6 buttons to select either OCEANIA (or OCE) or EUROPE - both are valid settings for New Zealand - see below for differences. 5. Switch radio off to store the change Voila! Your radio has now bee reprogrammed to receive NZ FM frequencies! Also, the cool RDS features will now be available. Differences between OCEANIA and EUROPE modes on an E46 Business RDS radio (other radios may vary slightly): a) EUROPE has LW, MW and FM. OCEANIA has AM and FM only. OCEANIA shows ST for a FM stereo station; EUROPE doesn't show anything for stereo or mono FM stations. c) EUROPE has the softkeys set to RDS and TP; OCEANIA has RDS and PTY Which ever one you choose - OCEANIA or EUROPE - is up to you, they both work. I hope you find this info useful, and that the forum moderator makes this a 'sticky' PS: If anyone wants any info or help with BMW radios - talk to me. I've helped around 80 BMW owners convert from Japan radios to proper NZ radios for their BMWs, thus keeping the vehicle in original condition, and obtaining proper radio reception. Send me an email for more info! Cheers, Jochen Hi Jochen - or anyone can help please! I just bought the e61 2006 525 Stationwagon and am wanting to change the radio frequency from Japan to NZ. I am stuck trying to locate the "M" button? Any help with this... Cheers Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted June 3, 2017 Read my previous post. It needs coding. Talk to Joe. google Eurosurgeon Quote Share this post Link to post Share on other sites
Mars 0 Report post Posted March 21, 2018 Hi I have a 2007 750i Wanna change the radio frequency from Japan to Oceania or Europe & i read Jochen's post on the same It says when the Radio turns on press the 'M" button - where is that "M' button ??? I don't see it anywhere Is it the Main i drive round knob you referring to ... Please help ... Thanks Quote Share this post Link to post Share on other sites
