ahmedc 4 Report post Posted April 4, 2020 Hi guys, I've got a 1989 318i M40B18 and I'm looking to get a new pilot bearing as I'm planning a manual swap. Does anyone know what dimensions I need for the pilot bearing to fit my engine? So far having a look online I'm to believe that the dimensions are as follows for the pilot bearing: Width [mm] 9 mm Inner diameter [mm] 15 mm Outer diameter [mm] 32 mm If that was the case then would a 10mm width x 15mm inner diameter x 32 mm outer diameter make much of a difference? Quote Share this post Link to post Share on other sites
Mad_Max 236 Report post Posted April 4, 2020 I believe there are two different sizes, depending on the input shaft diameter, so it depends on if your input shaft is 12mm or 15mm. The outer diameter is the same, and the thickness doesn't matter too much. Just measure the input shaft diameter of the gearbox you are using and order the bearing to suit that. Make sure you get the bearing installed at the correct depth too. 1 Quote Share this post Link to post Share on other sites
ahmedc 4 Report post Posted April 4, 2020 1 hour ago, Mad_Max said: I believe there are two different sizes, depending on the input shaft diameter, so it depends on if your input shaft is 12mm or 15mm. The outer diameter is the same, and the thickness doesn't matter too much. Just measure the input shaft diameter of the gearbox you are using and order the bearing to suit that. Make sure you get the bearing installed at the correct depth too. Sweet, thanks for that. Will measure it once I get it but I'm looking at a getrag 240 so can have a look online as to what the measurements are for that. Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted April 4, 2020 Brent (BM World) should be able to help you. There were 4 of each with all the parts he brought off me when I closed down to retire. Quote Share this post Link to post Share on other sites
ahmedc 4 Report post Posted April 5, 2020 Confirmed with Brent. Thanks a lot guys. He said the dimensions are fine. Quote Share this post Link to post Share on other sites
