HalfJobHarry
E8x E9x Washer Bottle / Sprayer issues fix guide
As promised a while back here is my guide/shared experience with things E8x washer / sprayer related.
Formatting needs a tidy up which I'll do if there content is useful/wanted or look at making a website/blog post or something as that might be easier.
EDIT: It's also worth mentioning that if your washer pumps are not leaking but you suspect you're strainers are gummed up....shoving very long plastic tubing (something from a fish tank place or similar) down into the tank and blowing can cause the dirty water to back flow. I've also driven compressed air through the sprayer lines on the bonnet back into the tank. These approaches provided some short term fixes...but sooner or later you are going to have to get in there...)
E8x and E9x Washer tank guide.pdf
Edited by HalfJobHarry
  • Thanks 1
