325_driver 422 Report post Posted July 13, 2020 So i'm trying to enable tyre pressure monitoring to my 2002 E46 (I want the option to have run flats) And i'm having an issue getting INPA to enable the RPA button (deflation detection system) which is F7 for me, the button is disabled. The steps i've gone through adding $251 to FA/VO -> FA_WRITE to AKMB -> FA_WRITE to ALSZ Then the coding / changing the values to the following files in (values on the video) AKMB -> LESSEN -> FSW_PSW.TRC -> MAN -> SG_CODEREN the two RDKS ^ this part codes no problem, car resets with the tyre pressure light showing as red, then orange, then off when ignition is turn on MK60 -> LESSEN -> FSW_PSW.TRC -> MAN -> SG_CODEREN ^ this part code issue And the DSC / ABS light remains on, plus when i take the hand brake off it goes orange ASC / ABS lights return to normal when i return REIFENDRUCKWARNSYSTEM nicht_aktiv in MK60 Quote Share this post Link to post Share on other sites
Dogballs 102 Report post Posted July 13, 2020 Try not doing the FA write. just code the specific values in AKMB and the MK60. I have done this mod, but from memory some early mk60’s won’t work. good luck.. I have a spare mk60 that does work if you need it.. Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted July 14, 2020 @Dogballs thanks, pmd you anyway. Quote Share this post Link to post Share on other sites
