13alis 0 Report post Posted July 17, 2020 Hey, just seeing if anybody has a second hand set of adjustable suspension for an e36 M3 that they want to get rid of? Before buying new. cheers guys! Quote Share this post Link to post Share on other sites
sirrocco 1 Report post Posted July 21, 2020 sent you a PM, cheers Quote Share this post Link to post Share on other sites
KwS 2448 Report post Posted July 21, 2020 On 7/17/2020 at 2:55 PM, 13alis said: Hey, just seeing if anybody has a second hand set of adjustable suspension for an e36 M3 that they want to get rid of? Before buying new. cheers guys! FYI, not specific to M3 unless you want offset top mounts. Just dont get a set from a compact/TI as they are different. I used E36 BC Gold in mine. Quote Share this post Link to post Share on other sites
13alis 0 Report post Posted July 21, 2020 Thanks man, was more so just trying to avoid the Cheap Chinese coilovers that don’t have the sway bar mounts. Also aware of the TI coilovers. looks like I have found a set now anyway! Quote Share this post Link to post Share on other sites
Gaz 1075 Report post Posted July 21, 2020 9 hours ago, KwS said: FYI, not specific to M3 unless you want offset top mounts. Just dont get a set from a compact/TI as they are different. I used E36 BC Gold in mine. The evo m3 are different, swaybar mounts to the strut not the control arm on the m3 Quote Share this post Link to post Share on other sites
KwS 2448 Report post Posted July 21, 2020 22 minutes ago, Gaz said: The evo m3 are different, swaybar mounts to the strut not the control arm on the m3 Sorry yes, you're kinda correct, Not specific to evo though. Most coilovers i've seen suit both options, but there are some exceptions obviously. Quote Share this post Link to post Share on other sites
