Cement 911 Report post Posted August 5, 2020 Hi hi ... I need to get the ECU / DME pinout for my 318ci E46 (NZ new with M43 engine). Basically all of the content I see online is for Siemens computers (MS43 etc), including resources at https://www.newtis.info/tisv2/a/en/e46-318ci-cou/components-connectors/components/a-control-units-modules/ My ECU is a Bosch unit 'DME 1 430 940' ... i see there are variances with pinouts on newtis for the various A6000 entries so keen to ensure i get the right info. Mucho thanks !!! Quote Share this post Link to post Share on other sites
Cement 911 Report post Posted August 18, 2020 Nobody has anything that might be useful ? Is it safe at least to assume the pinout is common and ECM simply manufactured by different companies ? Quote Share this post Link to post Share on other sites
NZ00Z3 190 Report post Posted August 18, 2020 Can't guarantee that its the same. I was doing research on 540i DME's which are Bosch on NewTIS. One day it was all there and I got half way through my research, the next day and ever since its been missing. Almost as if Bosch has pulled the IP. Quote Share this post Link to post Share on other sites
