andreas511
E36 Central Locking working but remote keys not functioning
Hi, I recently bought my 1997 320i (E36) with 2 remotes that do not respond to the Central Locking System.
Can anyone give me some ideas on how to diagnose this issue further? Thanks heaps!
They only thing I have done so far is:
1. Get in the car and close all windows and doors.
2. Put key into the ignition and turn to position 1 (the accessories should turn on)
3. Turn the key back to position 0 and take the key out of the ignition.
4. Hold down the unlock button, press the BMW logo (lock button) 3 times, and release the unlock button.
Doors do not Lock/Open,
I have checked the fuses, and the replaced the key batteries but no luck?
Are they 2 button keys or 3 button keys?
Is it a N.Z. new E36 or a Jap Import?
If like the e46 imports does it have a red dome shape under the mirror, clowns nose. If so this is the receiver part and does not have a good range plus you need to point the key directly at it. The key synco method can be tricky and timing is every thing. Have a search on here been talked about heaps. Let's us know how you get on.
Thank you NZ00Z3 !!!
This has solved my issue, with following the instructions in the PDF file everything back to normal now!  ?
Glad to have helped.
It took me ages to find that file when sorting out the IR remotes on a E46.
