C-130 Hercules
Obd2 recommendations
I am thinking of buying a diagnostic tool for home use. Any recommendations?
I would like to read out issues such as faulty park sensors, bad plugs, etc. It would be primarily used on a 2007 Mercedes. Fortunately my (older) BMWs don't have that many gimmicks so got away with it so far. ?
I have been using the Foxwell NT530 scanner with BMW software for a while now.  Its OK, does most things that INPA does and reads all modules in the car.  It talks both OBD2 and ADS.  ADS is needed for the older BMW's like the E30 and E36.  It also allows you to load two manufacturer's software at the same time, so you can load the Merceded software and be able to read all modules in your car.
https://www.foxwelltool.com/wholesale/nt520-pro-scanner-with-bmw-software-installed.html
