m_reaney
Power Steering Leak
I have a minor leak from a hose, although I have no idea where the power steering pump and hoses are. Can someone please tell me? Cheers
How do you know there's a leak there if you don't know where they are?
Anyway, power steering reserivor is under the MAF sensor, so pump and hoses would be below that.
I took the car in for a warrant and thats what I was told.
MAF sensor? (please excuse my ignorance) where is that? Cheers for your help
Edited by m_reaney
Guest Andrew
its pretty well buried on your car
Open the bonnet - on the right hand side (with you facing down the car) under the throttle bodies is a brown container - from there are power steering hoses.
Might be best to take to mechanic to get fixed.
Mass Air Flow sensor, it's just before the throttle body in the air flow path.
I had my car in at BMW yesterday, turns out it was just a couple of clips that needed replacing on the hoses.
Thanks for all your help.
Mike
