325GRANT 0 Report post Posted April 27, 2006 is anyone out there using an after market fuel pump? if so what are you using and is it working? Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted April 27, 2006 Try tune up the stock one with the large injectors and RRFPR - will be interesting at the least. I was gonna grab a Bosch one - it was around $800 - but probably overkill. Quote Share this post Link to post Share on other sites
IPLEZR 0 Report post Posted May 16, 2006 i have a internal 550hp walbro pump in my e30 easy to replace not sure how it goes yet as car isnt back on the road Quote Share this post Link to post Share on other sites
TronSpec 0 Report post Posted May 17, 2006 yeah man i got a vl commodore external fuel pump for my e30, runs plenty well. standard inpump one still with sender unit.... Quote Share this post Link to post Share on other sites
Damo 23 Report post Posted May 18, 2006 the 333 turbo uses a Bosch Motorsport 550HP external unit I brought in from Singapore, they want ridiculous money for them from the distributors here. Runs larger inlet and outlet though so you need to run bigger lines, but thats not a major and gives a huge safety factor - depends what your fuel requirements are. Quote Share this post Link to post Share on other sites
325GRANT 0 Report post Posted May 18, 2006 I brought in from Singapore, was it very expensive to bring in yourself? Quote Share this post Link to post Share on other sites
E30-323ti 66 Report post Posted May 18, 2006 (edited) I've got a Airtex pump from BNT in petone, same specs as the Bosch 901. Also has larger in/out's than stock and is quite noisy. You can come and see how I mounted it if you like. ps. was ~$290 IIRC Edited May 18, 2006 by E30-323ti Quote Share this post Link to post Share on other sites
