325GRANT
fuel pump upgrade
Guest Andrew
Try tune up the stock one with the large injectors and RRFPR - will be interesting at the least.
I was gonna grab a Bosch one - it was around $800 - but probably overkill.
i have a internal 550hp walbro pump in my e30 easy to replace not sure how it goes yet as car isnt back on the road :unsure:
yeah man i got a vl commodore external fuel pump for my e30, runs plenty well.
standard inpump one still with sender unit....
the 333 turbo uses a Bosch Motorsport 550HP external unit I brought in from Singapore, they want ridiculous money for them from the distributors here.
Runs larger inlet and outlet though so you need to run bigger lines, but thats not a major and gives a huge safety factor - depends what your fuel requirements are.
I've got a Airtex pump from BNT in petone, same specs as the Bosch 901.
Also has larger in/out's than stock and is quite noisy.
You can come and see how I mounted it if you like.
ps. was ~$290 IIRC
Edited by E30-323ti
