SmackJackTheCrackerMan 54 Report post Posted January 22, 2021 (edited) Hey everyone, I was just out for a short drive, car nearly up to operating temp and I put my foot down a bit up to 80kph and engine light came on. I have checked using MHD and I’ve a misfire in cylinder 6. What is my best option from here? plugs and coils? injectors? (Please noooooo!) any advise would be great. Edited January 22, 2021 by SmackJackTheCrackerMan 1 Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted January 22, 2021 just try another coil . swap the number 6 for number 1 etc and drive it again see if fault chases Quote Share this post Link to post Share on other sites
SmackJackTheCrackerMan 54 Report post Posted January 22, 2021 37 minutes ago, BM WORLD said: just try another coil . swap the number 6 for number 1 etc and drive it again see if fault chases Yup the code followed the coil to cylinder 1. best to replace the whole 6 at the same time? anything else I should check while I’m in there? Thanks for the help! Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted January 22, 2021 6 hours ago, SmackJackTheCrackerMan said: Yup the code followed the coil to cylinder 1. best to replace the whole 6 at the same time? anything else I should check while I’m in there? yea you could do all 6 also replace the plugs as they wear out they put more load on the coils . Quote Share this post Link to post Share on other sites
