KPS 0 Report post Posted January 27, 2021 Hi guys, Does anyone know any place in Wellington where I can get a CCC unit repaired. I have 330i 2006 E90 and its CCC unit keeps on restarting and stuck on the BMW logo. I am also hunting for a used CCC unit but no luck so far. Even, If I could able to get hold of one then it needs to be coded to match the VIN number. Would be great if anyone also posts about a place where I can get my BMW coded in Wellington, apart from the Dealership (they code only new units I assume). I don't mind taking my BMW to a buddy who does coding. Thanks. Quote Share this post Link to post Share on other sites
promo 93 Report post Posted January 27, 2021 Flick me a PM. I can help with coding. I may have a used ccc unit as well 2 Quote Share this post Link to post Share on other sites
Driftit 2222 Report post Posted January 27, 2021 I had that once. Nav system was faulty. Unplugged the Nav and it fixed it. But Pramod has all the gear to diagnose and fix your issue. 1 Quote Share this post Link to post Share on other sites
KPS 0 Report post Posted January 27, 2021 2 hours ago, promo said: Flick me a PM. I can help with coding. I may have a used ccc unit as well Thanks Pramod, done. Quote Share this post Link to post Share on other sites
KPS 0 Report post Posted January 27, 2021 1 hour ago, Driftit said: I had that once. Nav system was faulty. Unplugged the Nav and it fixed it. But Pramod has all the gear to diagnose and fix your issue. Right, would be interesting to see what the cause of the issue would be. Quote Share this post Link to post Share on other sites
promo 93 Report post Posted January 27, 2021 1 hour ago, KPS said: Right, would be interesting to see what the cause of the issue would be. CCC unit are so old now the processor starts to fail. most likely the solder needs to be reflowed. a bit of work involved as I use to repair these. 1 Quote Share this post Link to post Share on other sites
KPS 0 Report post Posted January 29, 2021 On 1/28/2021 at 10:47 AM, promo said: CCC unit are so old now the processor starts to fail. most likely the solder needs to be reflowed. a bit of work involved as I use to repair these. Right. Another reason which I can think of is not to code/register the new after-market battery which I bought from SuperCheap Autos one and half years ago. Now, I experience more electrical problems like for instance, sometimes car does not start first time (but it starts on second time). Sometimes, after inserting the key fob, everything is jammed then I need to unplug/plug battery again as a quick fix workaround. Genuine battery was 90Ah where as this new battery is 95Ah, not much considerable difference though I guess. Thanks Quote Share this post Link to post Share on other sites
Dave H 0 Report post Posted July 4, 2023 On 1/28/2021 at 6:38 AM, promo said: Flick me a PM. I can help with coding. I may have a used ccc unit as well Hi , looking to get an e90 ccc repaired. please txt me if interested. cheers dave 0272895804 Quote Share this post Link to post Share on other sites
JDALEY928 0 Report post Posted November 8, 2024 On 1/28/2021 at 10:47 AM, promo said: CCC unit are so old now the processor starts to fail. most likely the solder needs to be reflowed. a bit of work involved as I use to repair these. Hi promo, Tried to PM you but it didn't work. Are you still able to repair these units? Thanks Quote Share this post Link to post Share on other sites
