topnotchrally 164 Report post Posted February 15, 2021 As it says... Would like new/used rear shocks for the Z3. 1 Quote Share this post Link to post Share on other sites
NZ00Z3 190 Report post Posted February 16, 2021 I've been buying Meyle shocks and struts from MillAnd in Dunedin for the Z3's that pass through my workshop. Last set in Feb 2018 where $115 ex GST each. They are OK and comparable with the originals. If your Z3 is a Jap import, you'll likely find that it is fitted with M Sport suspension. Check your build spec. It's a 12 mm drop from the standard suspension. The correct shocks/struts for it are only available through BMW and are eye wateringly expensive. Just fit standard shocks/struts. Quote Share this post Link to post Share on other sites
topnotchrally 164 Report post Posted February 16, 2021 Thanks for the tip. My car is NZ new 2.8 without M suspension. KYB Excel-G can be bought at supercheap fro $130 inc GST each. Any experience with those? I'm look for something with a lot of damping. I would like Bilstein HD but that'll be $500 for the pair. Quote Share this post Link to post Share on other sites
NZ00Z3 190 Report post Posted February 16, 2021 Yes, KYB Excel-G have a good reputation in the Z3 world for an OE type of ride. Quote Share this post Link to post Share on other sites
