fred_ 166 Report post Posted April 17, 2021 (edited) Hi everyone I’ve just changed the battery in my E90 LCI and the interior lights, locking system, windows have all stopped working. My research suggests I’ve damaged the FRM3 module. Has anyone in Auckland had success repairing one of these or reset via coding, or have you had to replace the whole unit? note I have already registered the new battery to the car Any help greatly appreciated. cheers Alex Edited April 17, 2021 by fred_ 1 Quote Share this post Link to post Share on other sites
HalfJobHarry 106 Report post Posted May 17, 2021 (edited) On 4/17/2021 at 12:35 PM, fred_ said: Hi everyone I’ve just changed the battery in my E90 LCI and the interior lights, locking system, windows have all stopped working. My research suggests I’ve damaged the FRM3 module. Has anyone in Auckland had success repairing one of these or reset via coding, or have you had to replace the whole unit? note I have already registered the new battery to the car Any help greatly appreciated. cheers Alex Yes ... I had an FRM3 fault and was going to replace the unit until I discovered the pricing. In the end it turned out I had some corrosion on some pins that were shorting together...cleaning this up sorted me out. However I did a fair bit of research. First step is to determine if the FRM is still 'alive' at all...as in can it be seen on the CAN bus. If it cannot be seen then it's highly likely that the bootloader area has been corrupted (the common failure mode for FRM3). If I had a total failure I'd probably send it out to get repaired (overseas as to not get totally ripped off). I flirted with buying a Ali Express programming tool for the EEPROM (it cannnot be reprogrammed using the BMW tools) and maybe starting a little sideline here. The Xprog copies are only about $180 USD from Aliexpress. I'd wager there are a fair few programmers around that can do it....just about finding somebody locally that won't fleece you.. P.S. There are a bunch of worldwide BMW warranty extensions on FRM3... if you're under 10 years old I'd give the dealer a call and have a moan...worst they can say is no. Often dealers like doing this warranty work as they get paid for it by the mothership. Edited May 17, 2021 by HalfJobHarry Quote Share this post Link to post Share on other sites
The Bimmer 12 Report post Posted July 3, 2021 For bmw/mini E series frm3 repair,I can help you.Plug and Play No Coding Required Quote Share this post Link to post Share on other sites
