Ryan94
Engine light with code P0101
Morning! Wondering if someone can help please. My engine light came on about 2 months ago I thought it was the MAF sensor so I changed this and the engine light went. About 2 weeks ago the light came back on with these faults, now I think it’s the MAP sensor. Any thoughts if this is why the engine lights on? I’ve had this car for 8 years now and always been well maintained, think it’s just getting to that age now where things are gonna start going wrong 🤬😂 if it is the MAP sensor, where is this located? I’ve taken the engine cover out and also the other plastic surrounding it and I can’t see it anywhere... any help, advice and suggestions will be much appreciated! Thanks
Hiya,
Had similar issue. Turned out to be a vacuum leak which caused the maf fault. Get a smoke test done on the vacuum lines
