Jacko 2371 Report post Posted August 15, 2021 Anyone successfully repaired a magnesium rocker cover before? Its seems theyre are the age where 95% of them are corroded. Most of them seem to blow holes down the coil tubes, and a couple blow out the inner mounting bolts. Im thinking grind out the rot, then treat in something, then rebuild with JBweld/Ali plug or something, then respray in something protective... Its not exactly structural but will need to be relatively temperature stable. Quote Share this post Link to post Share on other sites
Jacko 2371 Report post Posted August 16, 2021 Think this one's terminal, the rot keeps going.. Black dust gone intergranular. Might just have to bite the bullet and spring for a new one 😕 Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted August 16, 2021 4 hours ago, Jacko said: Think this one's terminal, the rot keeps going.. Black dust gone intergranular. Might just have to bite the bullet and spring for a new one 😕 Is that not grounding spark plug damage? Sometimes the boots fail to insulate so the spark jumps to the alloy and damages it. Could be at play? Quote Share this post Link to post Share on other sites
Jacko 2371 Report post Posted August 16, 2021 4 minutes ago, Michael. said: Is that not grounding spark plug damage? Sometimes the boots fail to insulate so the spark jumps to the alloy and damages it. Could be at play? Nah, well maybe in a few spots (or thats what blows the protective ali coating off and starts the corrosion), but others are around bolts etc. Quote Share this post Link to post Share on other sites
